I'm not sure I understand how or why the ANT-751 got into this situation. I would not expect the ANT-751 to be able to provide reception of WTAE. That you see lower signal quality with the ANT-751 outside is interesting... but irrelevant, because it's not enough antenna for your situation.
If you want to see WTAE, you need a high gain (therefor quite directional) antenna. The big Winegard HD7698P qualifies... as do the DB-8 / YA1713 combination.
I doubt you will have as much success in the attic... certainly not in the wet and snowy month of the year.
