Tv Antennas and Reception
You are having great fun with the DXing. As you are finding out when the signal is in , it can be quite strong and last for hours. Skip , Tropo , Ground wave , reception is very interesting and a lot of fun. An even better antenna for DXing would be a Winegard HD7082P all channel antenna on a Channel Master CM9521A rotor. Or as you are finding out , the Ham radio equipment rotors are much more heavy duty rotors. Tv DXers that are all the way into it , use separate , UHF antennas , VHF high antennas and VHF low antennas. They are after the very elusive tv stations.
