Old 26-Sep-2011, 3:15 AM   #1
kevinmathewson
Single channel causing problems with TV (aka Problem in Peoria)
I have an issue with one channel (actually two if you count the subchannel). It is the NBC channel (25.1 and 25.2). When I switch to the station it stays on the tv-good picture and sound-for about 5-10 sec and then the picture completely drops, leaving sound for another 15-20 seconds. At that point my tv is completely unresponsive and requires me to shut it off and when it comes back on try to change the channel in the first few seconds that NBC is on. Sometimes while the audio is still on I can change the channel (although no picture comes up on the newly selected channel) so when I turn off and on the tv I am on the new channel. This only occurs with that specific channel. All other stations (ABC, CBS, FOX & PBS) work just fine. Could the channel be causing a problem or is something wrong with the tv for the 25.x range of stations?
I have a Sony Bravia (3.5 yrs old) with a RCA flat antenna from Wal-Mart sitting on top of the entertainment center. I live less than 8 miles from the tower. I believe the FOX tower is the farthest away (~25 miles) and the signal is fine.
It's the only HDTV I have so I can't really troubleshoot it by swapping out with a different one.
Here's the report: http://www.tvfool.com/?option=com_wr...60b5b51f42da1e
I'm perplexed. Anybody have any suggestions or have seen anything like this before?
Thanks.
kevinmathewson is offline   Reply With Quote
