Old 14-Apr-2010, 1:16 PM   #40
Tower Guy
Originally Posted by Dave Loudin View Post
However, in this case, the two markets we're looking at are virtually 90 degress apart, so very little signal from one should be getting into the other.
The 90 degree separation does prevent interaction of the antenna patterns. All that means is that the line lengths to the combiner can be random. However, any structure located 90 degrees away will cause multipath. Most adaptive equalizers need a bit more signal to decode the 8 VSB signal when there is multipath.
The suggestion of an A/B switch is intended to reduce multipath and eliminate the loss of the combiner
