DL suggested a Winegard HDP-269mplifier which can handle strong local signals better than most other amplifiers. A worthy competitor to the Winegard would be an Antennas Direct CPA-19.
I'm rather hopeful you'll find a single aim point that works well. I would suggest aiming directly at WIPX, 192° per your compass. Then, if needed, adjust a bit toward the west to deal with any stations that might be a bit weak due to the aim being a bit off. The stronger signals SW of you will be easier to receive than WIPX.
A rotator will frustrate viewers who want the antenna aimed some direction other than where the person with the rotator remote chooses. If you must have a rotator, the Channel Master CM9521a is a consumer grade (priced) option. For larger antennas and locations prone to extremely cold weather, the Hy-Gain AR-40 is a far more robust rotator (as it's price would imply).
