Ok, so now you suggest the HD7000R over the HD7694P? Or either would be fine? No that I mount it to the roof, I need to run it down to the basement, where I will split it. That run will be about 40 ft. The split goes to a TV about 20 ft away in the basement and the other to a TV that existing cabling goes up to the attic and back down too. I will probably put an amp before the splitter. Any suggestions on an amp, a 2-way splitter, cable from antenna to splitter, and grounding wire? thanx again.
