Old 24-Sep-2011, 3:40 PM   #7
No static at all
No static at all's Avatar
Either antenna should work fine. I would personally use the Winegard HD-7694P to also bring in Maryland Public Television from Annapolis MD. Not sure if that is on your wish list though?
I helped a friend in Vienna with an antenna project recently. We ended up using the RCA-ANT751 about 6 feet off the ground & it does OK with an occasional hiccup. (No MPT though) He did not want a rooftop antenna & rabbit ears did not work well inside.
