Old 23-Sep-2011, 9:41 PM   #3
Do Not connect the Tv Antenna to any part the active Fios coax cable system. Yes you can use the coax wiring that is in or on your home to get the tv antenna signal from point A to point B , however do not use any part of the coax if it has any type or kind of active Fios on it. Active Fios cable tv service , Active Fios internet service , Active Fios phone service or any other type or kind of active Fios service on the coax , Do Not connect the Tv Antenna to it.
