Old 23-Sep-2011, 2:01 AM   #2
Mounting an antenna on a light pole should be done with great care. If there is power present, take appropriate precautions to avoid any possibility of the power and antenna systems contacting one another.
A 200' run of RG-6 coax would have about 12 dB loss. An Antennas direct CPA-19 preamp would be a good choice for overcoming that loss.
An omni-directional antenna would not have enough gain to reliably receive the weaker signals. I would suggest using two antennas:
A 4-bay panel antenna such as the Antennas Direct DB-4 facing 318°
A Winegard VHF HD5030 pointed at about 45°
Combine the two antennas with a UVSJ signal combiner, which would connect to the input of the preamp.
