Old 23-Sep-2011, 2:00 AM   #23
inspector
To ground an antenna. Take and drill a hole on the holding mast as best or us a clamp. A grounding wire has to ground. The best source for that is the ground (dirt). strip the casing from the wire and bury the exposed wire into the ground for the easiest way. The proper way would be to expose wire and then attach to a grounding rod and drive it into the ground. Pick a spot such in your case being at the house, under a down spout area as moisture helps with the grounding capabilities.
inspector is offline   Reply With Quote
