You do not want a plastic-enclosed antenna, ever, as it will turn brittle and crack due to ultraviolet radiation. Now for the good news: all your stations transmit in the UHF band (14-51) (see the "Real Channel" column), and are all very strong (the noise margins are very large positive numbers for your local stations), so you need a modestly sensitive UHF antenna. Two options: mount an Antennas Direct ClearStream 2 outside facing almost due east (80 degerees) or try a Terk HDTVi indoors.
