Old 21-Sep-2011, 5:05 AM   #10
Here is the web site for the converter box , http://www.accesshd.tv. The GXi DTA1030D is a Access HD DTA1030D. The owners manuals and connection guide are at and in the web site. The Connections Diagrams are at and in the web site. The antenna is connected to the converter box , not the tv. The converter box will output on channel 3 or 4. If using the RF out , also known as out to tv , on the converter box , to the tv , the tv will be on channel 3 or 4 , Try channel 3 on the tv first and then try channel 4 on the tv. The converter box does ALL of the digital channel selection ,<-- did you notice the word ALL?? The converter box outputs a channel to the tv , 3 or 4 . The tv receives the Channel 3 or 4 signal from the RF output/also known as , out to tv , of the converter box. When you see the digital channels on the tv screen then leave the tv on channel 3 or 4.
