Old 20-Sep-2011, 10:00 PM   #22
be236
Closed or open loop?
Another question... I have an ohmmeter so I can measure the RG6 cable, the inside and outside shielding... Once I connect my RG6 cable to antenna leads via twin-lead to coaxial adapter, and I measure for ohms across the terminal of either the RG6 itself or directly on the antenna leads, is it open (infinite resistance) or closed (some ohm readings)?
