Old 20-Sep-2011, 7:01 PM   #4
The DB-2 sounds as if it's doing fairly well for you now. If you replace it with a larger, more directional antenna, I would expect that you would need a rotator to make full use of the new antenna.
If you have more than one TV, a rotator can be a source of conflict when the second TV viewer wants to tune a station the antenna is not aimed at.
A Winegard HD7698P mounted where it can have an unobstructed view, would offer reception of all of the stations listed in the green and yellow section of your TVFR (presuming they are on the air). It's a long antenna. A tripod and heavy duty mast would be worth considering. The Channel Master CM9521A antenna rotor would be a consumer grade option, the Hy-Gain AR-40 would be a premium grade option.
The weaker signals would call for a good low-noise preamp. There are several strong TV and FM signals so an amplifier with high input capability would be needed. The Antennas Direct CPA-19 or Winegard HDP-269 would be capable of meeting both requirements.
