Old 20-Sep-2011, 4:35 PM   #13
be236
Originally Posted by MisterMe View Post
Is KFFV the only digital station that your Sony can't receive or does not not receive any? If KTTV is the only station that you can't receive, then lack of tuner sensitivity may be the reason. If you can't receive any digital stations, then the explanation is likely the fact that older wide screen TV sets did not have integrated ATSC [digital] tuners. If this is the case, the you need an external tuner or converter box like your Artec.
No, KFFV (44.x) is the only channel my Sony (yes, it's HDTV with ATSC tuner) can't get. All the other digital channels it gets fine like the Artec DTV converter box.
So, like I said, I suspect because it's an older Sony model, its ATSC tuner is not as sensitive as the Artec DTV converter box I bought in 2009 as US went Digital.
Is there a listing of newer HDTVs ranked my tuner sensitivity so I know which model to buy for my next TV so I can pick up those weak Vancouver stations (get a better chance of digital lock on low NM values as listed in tvfool)?
be236 is offline   Reply With Quote
