Old 20-Sep-2011, 4:25 PM   #12
MisterMe
Originally Posted by be236 View Post
I've got an older Sony HDTV CRT (2006?) that can't pick up channel 44.1, while my newer DTV converter box (Artec) can, using the same cable. Must be because this Sony was older, so I am guessing newer Sony tuners are more sensitive.
Is KFFV the only digital station that your Sony can't receive or does not not receive any? If KTTV is the only station that you can't receive, then lack of tuner sensitivity may be the reason. If you can't receive any digital stations, then the explanation is likely the fact that older wide screen TV sets did not have integrated ATSC [digital] tuners. If this is the case, the you need an external tuner or converter box like your Artec.
MisterMe is offline   Reply With Quote
