Old 20-Sep-2011, 4:09 PM   #9
rickcain
You might just try recrimping all coax connections with higher quality compression fittings. Bypassing existing coax is a great solution especially if you suspect the old coax is rather dodgy or is the skinny RG-59 stuff. Coax is so inexpensive now its worth the small investment in money and time.
Put terminators on any wall plate jacks that aren't being used.
rickcain is offline   Reply With Quote
