Old 20-Sep-2011, 7:44 AM   #2
Read and understand about analog to digital transition of the USA and Canada , http://forum.tvfool.com/showthread.php?t=695 , http://www.tvtechnology.com/article/117022 , http://www.tvtechnology.com/article/105462 , http://www.user.dccnet.com/jonleblan...da_TV_stations. You can go to the forms of , http://www.digitalhome.ca , for update information. Also tvfool is being up dated. The pending applications that may not reflect the latest information shows , analog CBUT 2 , CHAN 8 , CHEK 6 . Digital , CHAN 22 , CBUT 43. In any event , if you will like to reach out for the Canada stations now or after the tvfool up date , at your location a Big Antenna will be needed. I recommend a Winegard HD7084P antenna or a Channel Master CM3671 and a Antennas Direct CPA-19 preamp. I recommend a dedicated antenna for the Canada stations.
