Old 20-Sep-2011, 12:59 AM   #15
mtehonica
Thanks again for all the help! One last question.... you said it needs to be mounted as high as possible on top of the roof... It's a single story house and the peak is probably 12 feet or so. If I use the j mount, within 6 inches or so of the peak, would that get it high enough? I guess with a 40" j mount, that would put the antenna about 14-15 feet above the ground?
mtehonica is offline   Reply With Quote
