help
First John, thank you for your help. I have only the Winegard HD7698P and the HDP 269 pre amp on a 35 ft. Rohn tower. the pre amp was designated with the "squareshooter" name, sorry for the confusion. The antenna set up has a CM rotor that is working. I will attempt to get a signal again in the 117 direction to see if I can get the other stations.
