The 91XG is a UHF-only antenna. Were you aware that you have two local VHF signals, WGTV 8 (PBS) and WXIA 10 (NBC) before buying this? If you're lucky and can see those two stations, then you probably need not do anything else. (Expect to receive all the channels at 218 degrees down to WDTA-LP 35 (53.1) or WTHC-LD 42) If you can't, then we need to talk further.
