Old 19-Sep-2011, 9:12 PM   #2
Without knowing which 19 channels you're seeing, it's hard to offer much advise. Comparing your TVFR to http://www.rabbitears.info/market.ph...n=WUTV#station it looks like you may be missing a few channels. As you look at the list of stations on your TV Fool report, are there stations listed that you do not receive that you would want?
Are you having problems receiving any channels now?
It would help if you used the Call sign and 'real' channel number.
With a large antenna, you could be receiving some Canadian stations which I doubt you are able to see with the DB-2. You may or may not be having trouble with local VHF stations.
Do you have more than one TV connected to the antenna? (Or do you plan to connect more than one?)
