Old 19-Sep-2011, 2:03 PM   #5
Dave Loudin
The two low-VHF translators (on 5 and 6) relay KOTI, which the OP should receive readily. Save some money (at least $20) and get the Winegard HD 7696P instead. Per your TVFool report, you have line-of-sight to a host of stations. You probably had LOS to the analog facilities, so your statement about not getting much even back then leads me to believe that you should check the cable from the antenna to your set-top box. If you think you need to replace it, use RG-6 coax and a new balun.
