Thread: reception help
Old 19-Sep-2011, 8:08 AM   #5
John Candle
Tv Antennas and Reception
For my recommendation the square shooter will not be used at all. For the reception of the digitl tv stations to the east south east , WLFI at 81 degree magnetic compass and the group of stations at about 117 degree magnetic compass I recommend aim the HD7698P antenna with the HDP-269 preamp at about 117 degree magnetic compass and scan for Broadcast Digital Tv Stations. And for the tv stations to the west south west , you have a choice , the one HD7698P antenna can be put on a Channel Master rotor CM9521A , or , a second HD7698P antenna with a HDP-269 preamp can be installed and aimed at about 263 degree magnetic compass. If you choose the 2 antenna solution , then separate coax from each antenna will go to the location of the tv and a , AB27RS , remote control A/B antenna switch will select the 2 antennas.
