Old 19-Sep-2011, 5:47 AM   #4
August 31 , 2011 was the 'main' analog to digital transition date for Canada. Tvfool is currently being up dated to show the new digital and analog channels in Canada. Canada will have a mix of digital and analog channels for a long time in to the future. And analog channels will be changing to digital channels as time goes along. Some tv stations will move to new geographic locations , and that is the way it will be. http://www.tvtechnology.com/article/117022 , http://www.tvtechnology.com/article/105462. For your location I recommend a Channel Master CM3679 antenna mounted on a Channel Master CM9521A rotor , the current and pending applications list shows analog and digital channels all around the compass. The rotor will allow you to turn the antenna to find and watch tv stations. I recommend print out the current and pending applications list so you will more easyly know when tvfool is updated for your location. Here is a place to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com.
