Old 11-Apr-2010, 2:14 PM   #1
fletch99
Attic antenna advice
I know outside is the place for an antenna. That said this is an attic setup for now. I would like to improve my reception.
Currently I have an HBU33 aimed at 140 degrees + Home made mounted horizontally pointed at 310 degrees => reversed 2-way splitter => 269 pre-amp => 3-way splitter.
When I turned the HBU to 140 I pretty much lost WWBT 12 which is VHF 26KW. Adding the home made antenna got it back but later I realized it was VHF so I'm not sure why the home made, which I think is UHF only, helped.
http://www.tvfool.com/?option=com_wr...9c6b8a3c0f19dd
Having some difficulty with WCVE & WCVW & WUPV
I can get WVBT ION but only late and early and never very strong signal. This seems to be the weakest signal this setup can pick up.
I've wondered if I removed the home made and got a 91XG and aimed it at 140 and aimed the HBU33 at 310 and still combine the signals then the pre-amp if I could make a big improvement. I honestly don't know but am looking for an economical way to improve this setup.
fletch99 is offline   Reply With Quote
