There's no such thing as an "HD" antenna. You need an antenna that is sensitive to the channels in the air at your location. The TVFool report tells us what those channels are - they are listed in the "Real Channel" column. Note that you have digital broadcasts on channels 6, 9, and 13 in the VHF band, with the rest in the UHF band. That is why you need to reuse the old antenna, or use John's recommendation.
You should drop by the reception results sub-forum within the OTA Television forum at digitalhome.ca. Find the thread for your area and see what others have done.
