Old 16-Sep-2011, 8:18 PM   #15
For attic installation, you could use chain-link fence top-rail, electrical conduit, PVC pipe... curtain rod, closet rod... so long as the antenna clamp can tighten on the rod, pipe or tube. Hung from the rafters, plastic will remain straight, mounted to the joists, expect it to bend or sag.
For an outdoor install, some creativity is OK, but obviously the wind, sun and rain are going to need to be considered. Mast product can be counted on to deal with the harsh conditions outside.
Home Depot will have something that will work well in the attic.
I'm not recommending it, but I know of antennas suspended on 1/8" cord in an attic for years. One line on the front and two at the back, the aim and tilt where adjustable. It worked...
