Old 16-Sep-2011, 1:36 PM   #1
hanleyh1
Need indoor antenna, Orlando area
Hi,
I recently moved into a two story townhouse in Windermere, FL (southwest of Orlando) and would like to get the 'majors' (ABC, CBS, NBC, FOX) and anything else digital or otherwise. I hooked up a cheap set of rabbit ears and when pointed out a 2nd story window, can get ABC, FOX and sometimes NBC (and even then, these are sporadic - the antenna has to be pointed just perfectly), but never CBS.
Here is my tvfool report:
http://www.tvfool.com/?option=com_wr...14f35bdaa08d53
As you can see, some of these 'majors' are 30+ miles away.
Because of a HOA and townhouse location, I don't think I want to try an outdoor antenna just yet. There is an attic in the townhouse with enough room for a good size antenna.
Any recommendations on what would do the job? I'd like to feed the antenna into the wiring of the townhouse so it will feed three TVs. Would I need an amplifier?
Thanks for any help.
hanleyh1 is offline   Reply With Quote
