Old 10-Apr-2010, 8:51 PM   #2
LovesTheOTA
Most indoor antennas imo are garbage.
Looks like you have some really nice strong signals and they all appear to be UHF which is good cause you can do it with one antenna. Instead of an "indoor" antenna from Walmart etc. I'd buy a quality 2bay or maybe 4 bay antenna (Channel Master, Antennas Direct) and put that indoors in a window or maybe in a closet.
I'd point the antenna directly at 324 degrees to pull in WXII NBC and WUNLV PBS. The other main and stronger networks should come in strongly off the backside of the antenna. They line up really nicely. You could try removing the reflector off the back of the antenna to help you pull in those stations off the back if you need to.
On a final thought I'd really just go for the 4bay and forget the 2bay and yeah you can do that for under $60. Its a good strong antenna.
If you ever feel like putting that thing outside there would be tons of stuff available for you to pick up although most of it is repeats of NBC, ABC, etc.
LovesTheOTA is offline   Reply With Quote
