Old 15-Sep-2011, 9:26 PM   #7
John Candle
Tv Antennas and Reception
If by south west you mean WOI-DT 5 , KCCI-DT 8 KDMI-DT 19 the answer is no , those stations are Very Weak and will require a large antenna to receive and most likely would not be received reliably. If by south west you mean , north , then the answer is no , the receivable stations to the north are NBC , ABC , CBS , PBS , these stations can be received with the HD7694P , however the antenna will need to be on a antenna rotor , rotors work ok with one tv however if more then one tv is connected there will be disagreements about where the antenna is pointed. A second antenna can be installed and pointed north , that means double the coax wiring. All of the networks such as NBC , ABC , CBS , PBS , FOX , ION and More will be received with one antenna pointed south east.
