Old 15-Sep-2011, 7:10 PM   #13
Croq
My SiliconDust HDHR tuners are equipped with two tuners each. Each HDHR has two F connectors. I use two splitter ports for each HDHR. The new HDHR3 still has two tuners but only one F connector.
The bottom line is, if you are only cabling to three F connectors, use a passive 3-way splitter. I really doubt you will need to use any amplifier.
I have two Hauppauge WinTV-HVR-2250 dual tuner internal cards, each with one F connector. Well, technically, it has two connectors, but the other one on each card is for FM (not interested).
The other one is an OTA connection for my satellite receiver (dual-tuner, one F connector).
So, 3 F connectors, 6 tuners. Nice to have the PCT thing in reserve though should it turn out that I need it.
Croq is offline   Reply With Quote
