Old 15-Sep-2011, 6:25 PM   #12
My SiliconDust HDHR tuners are equipped with two tuners each. Each HDHR has two F connectors. I use two splitter ports for each HDHR. The new HDHR3 still has two tuners but only one F connector.
The bottom line is, if you are only cabling to three F connectors, use a passive 3-way splitter. I really doubt you will need to use any amplifier.
The PCT and Channel Master are the same so far as I can tell. I have first hand experience with the PCT-MA2-M and a PCT-MA2-8P. I've not seen any hint of overloading when driven with stronger levels than shown in your TVFR.
