Old 15-Sep-2011, 5:21 PM   #10
Croq
If I understand you correctly, that you have four, maybe five tuners total, you're thinking correctly, at least two ports will see splitter losses equivalent to that of an 8-way split (10.5 to 14 dB).
I think so. Though I actually miscounted originally...
The feed from the antenna would go into a 3-way splitter. The three wires coming out of the splitter would each connect to dual-tuner devices (like a dual-tuner TV card for Media Center). So if I'm calculating correctly this time, that would make a total of 6 tuners.
I'll definitely look into your suggested amp if needed. I have a combo splitter/amplifier made by PCT that I might try first though.
Thanks again for all your help!
Croq is offline   Reply With Quote
