Old 15-Sep-2011, 4:35 PM   #8
Croq
A couple more questions...
If I want to split the incoming signal 4-5 ways (will be likely split 4 ways and then each leg would be split in two, so does that mean 8 ways?), do you think I'll need to get a pre-amp? Or should I just hook it up and see (they are easy to retrofit later, right)?
If you do recommend a pre-amp, any guidance on which one to get would be greatly appreciated too.
Croq is offline   Reply With Quote
