Old 10-Apr-2010, 1:08 PM   #13
Tower Guy
Originally Posted by kb2fzq View Post
Any suggestions as to a direction I might go to correct this? (Yeah, I know, I'm a dreamer, ain't I)
You can offset your two antennas to the left and right of the mast. The offset distance would be calculated to make the distance 1/2 wavelength at the angle toward WMFP when the antenna is aimed at WNYT-18. The antennas would still be in phase on the main beam.
There's also a channel 18 in St. Johnsbury, VT. How sure are you that the interference is caused by WMFP?
What's your goal with reception of 18? Are you having problems with channel 12? (The ERP on channel 12 will be increasing slightly.)
