Thread: Antenna Help!
Old 14-Sep-2011, 9:31 PM   #29
Ziffster
I would be inclined to aim the VHF antenna directly at CH-13 to reduce the amount of power form CH-10. Install the CPA-19 on the output of the VHF only. As you say, combine the amplified VHF with the unamplified UHF.
If you run into overload problems you can still add a UVSJ ahead of the CPA-19 with the UHF port terminated by a 75 ohm 'F' terminator cap. That would suppress the UHF power received by the VHF antenna another 20 dB or more.
The UVSJ used to combine the signals from both antennas would need to pass power through the VHF port or be located downstream of the CPA-19 power insertion block (which needs protection from the elements, it's designed for indoor installation).
Thanks! That got me thinking - what about using an actual attenuator like:
http://www.summitsource.com/eagle-10...k-p-10481.html
Ziffster is offline   Reply With Quote
