Tv Antennas and Reception
The CM7777 is a 2 part preamp , the out side part is the actual preamp , the inside part is the power supply , a coax goes from the preamp to the connection that says 'in from antenna' on the power supply unit and a coax connection is also on the power supply unit that says 'out to tv' , the 2 way splitter is connected at some point after the 'out to tv' connection. For maximum reception I recommend a Winegard HD7698P antenna. For less then maximum reception I recommend a Winegard HD7694P antenna.
