My impression with the CM7777 is that you should only have a single set connected to it and have an un-spliced, un-split coax to the transformer. Supposedly the power from the transformer and/or the signal from the amp would be weakened with a splice/split. The input is currently set to 'combined' on the CM7777. Any suggestions on a different antenna?
