Tv Antennas and Reception
I made a big point and clearly stated the answer is NO do not combine the 2 antennas on to one coax. It is possible to separate and combine tv signals that are in different tv bands such as VHF and UHF in certain situations , However your reception situation has a mixture of both VHF and UHF to the north and south. Do Not put both antennas on to the same coax. Well you can try it if you like , you will find that reception results are less then desirable and you will go to separate coax.
