Old 14-Sep-2011, 1:34 PM   #10
akrob
TV antenna and reception
Thanks. I will have the tv dedicated to the antenna, cable internet will be on seperate lines. Is it possible to use a diplexer to merge both antenna's down the same cable then split again when it enters the house? I would use an a/b switch inside at that point.
akrob is offline   Reply With Quote
