Tv Antennas and Reception
As for tv antenna height , 98.6437890166789521 % of the time , Higher Is Better. The signal strengths are calculated at 20 feet. That 20 foot high antenna signal strength is calculated with no trees or local obstructions in the way of reception. So moving the antenna where there are no trees is the original calculation , so the answer is , at least 20 feet high.
