The coax cables from the antennas will be separate and Will Not be connected on to one coax. For one tv hook up the coax from each antenna will go to the location of the tv and a remote control A/B antenna switch will switch select the antenna and connect it to the tv. A/B switch , AB27RS. If 2 tv's are connected then 2 way splitters are installed on each antenna coax and the outputs of the 2 way splitters go to the 2 tv's and A/B switches.
