I'm over in sanbornville nh about 16 miles south of porter and WGME is my toughest ch to get.
You will need to get out of the attic to get your weak channels.
for me I've done best with yagi and lpda antennas with a cm-7777 amp.
A cm 4228 old style didn't work well for any channels i suspect multipath to be the problem.
Current antennas I'm using that work very well here are a
Fracarro LP45F Log Periodic Dipole Array with a Antennacraft Y5-7-13
If you are in the trees and hills like i am you may be in for a ruff go at this as WCSH and WMTW are very strong and will probably over load most preamps.
Google earth is great for figuring out whats around that could block signals or cause reflections and it took me many try's to find a hot spot for WGME but once found it is very reliable here.
This is my location 43.56017818331089 -71.01229906082153
Free TV is great but not always easy.
