Combining two identical antennas?
Getting a signal in my house is a difficult thing because I live on the opposite side of a hill from the transmission towers. I've tried several antennas and found that the ClearStream2 mounted in my attic mostly works. The problem is, i get about 2/3 of the stations if I mount it on one side of the house and a different 2/3 if I mount it on the other side (about 1/3 overlap). There must be some interference from the ducting in the attic or something.
So it occurs to me that if I have a second ClearStream2, I could just mount one at each location and combine the cabling into one coax cable that feeds the TV. Since they are two identical antennas pointing at the same transmission source, it stands to reason there won't be any technical problems with ghosting or signal interference. Can anyone confirm that thought?
Also, in my case, I don't believe I need any sort of special antenna combiner. It seems I should be able to just splice the coax cables from each antenna together and call it a day. Am I right?
Thanks!!
