Embedded in the OP's ...Results.doc,
http://www.tvfool.com/?option=com_wr...8e44510a7623f6
@ treefrog, If your TV has a digital tuner (ATSC) it needs to use the 'air' or 'antenna' mode, not 'cable'. Cable systems generally use a different digital format. Check your user manual for specifications, the abbreviation, ATSC should be listed, as well as setup instructions. If you can't find the manual, many are available for download, simply search using the model number of the TV. If you like, post the model number of your set here.
