Old 12-Sep-2011, 1:33 AM   #1
treefrog
No Signal; have TV Fool Report - rooftop antenna (C 490)
Hello All,
I just installed an AntennaCraft C 490 on the side(gable) of my house of today. I have it approximately 8 feet above the roof line. From the attached TV FOOL report (thank you), I determined that the best azimuth would be 110 degrees.
I ran the coax into the basement and hooked it into the "in" port on a RCA 10db booster/splitter. I then hooked up the coax from the cable outlet in the bedroom to the "out" from the RCA splitter. I hooked up the TV (non-HD) to the cable wall outlet and did not receive any defined signals...just variations of wavy lines for some channels.
The house is surrounded by trees...the antenna would have to be moved up approximately 30 - 40 more feet if it were to have a chance at clearing the tree line.
Are the trees a problem?
Thanks,
Chris
treefrog is offline   Reply With Quote
