Old 11-Sep-2011, 7:03 PM   #7
Originally Posted by John Candle View Post
Grounding the coax does suppress and direct to ground unwanted manmade transmissions of all kinds , electric , electronic , magnetic . And grounding the coax does suppress and direct atmospheric electric static and magnetic build up to ground. This information and almost every thing else is look up able on to internet.
I'll agree that connecting the coax shield to a low impedance ground will hold the shield near ground potential for a fraction of a wavelength along the coax. At DC and power line frequencies, that will include the full length of the coax in most installations. At 195 MHz (TV CH-10) a full wave length is a bit more than 1.5 meters. Effective grounding of that frequency will extend significantly less than one quarter of that distance from the ground block with a zero impedance connection to a perfect ground.
Please cite some credible sources that can explain how the inductance and capacitance of the coax shield can be selectively ignored.
