Old 11-Sep-2011, 4:22 PM   #1
hillpc
How far in from the trees does the signal diffract back in?
...or maybe reflect back up off the ground?
My large Radio Shack VU-210XR combo antenna at 25 feet up is pointing directly at my desired station (FOX, Philadelphia channel 29, actual channel 42, and a number of others; see attached tvfool signal analysis), but the foliage of a 70 foot tall oak tree is literally inches away from the tip of the antenna. It's up against the tree leaves and pointing into the tree. Channel Master 7777 preamp to deal with the 80 feet of RG-6 and splitter, though right now I've removed the splitter to try to help. No trace of a signal, either on my hdtv TV or a cheap digital/analog converter box, though I know I was able to receive this channel in the winter. I do get others from the same direction at this time, those ranked (by Noise Margin) numbers 2, 3, 4,and 5 in the tvfool analysis. In the winter I get a good bit more.
With much effort (it's a huge antenna, with rotator ) I could move the antenna to the chimney area near the center of the roof, which would get it out of the leaves, but then there's still a whole forest of 70 foot tall trees about 60 feet away, in the desired direction. (There's a treeline of 70 foot tall trees in all directions, some closer than others.)
I'm wondering if the channel 42 signal coming over the trees gets diffracted enough to fill in the pattern in the 60 feet of distance from the treetops to my chimney, enabling reception. The cartoons of "UHF diffraction" and then also "Average power diagram" under the heading "Trees and UHF", at http://www.hdtvprimer.com/ANTENNAS/siting.html does not look promising, if it's to scale, though I don't know where the strong center beam comes from in the tree cartoon. Channel 42 should do a little worse than channel 35 used in that simulation, if I understand correrctly. Doesn't it also help that the transmitting tower is (presumably) much higher in elevation than my chimney? The cartoons show the waves coming in horizontally.
I could see myself wasting a bunch of effort if the trees 60 feet away kill the signal anyway. (Also, the hdtvprimer website poo-poos the use of cheap unspecialized field strength meters with today's digital signals.) If the trees'll kill it anyway I'd have to wait for the leaves to fall (we'll be halfway through footbal season by then) or put up a monster tower to get above them.
hillpc is offline   Reply With Quote
