Tv Antennas and Reception
Use a known to be good matching transformer to connect the RG-6 coax to the antenna , matching transformers can be bad even though it looks good from the outside. Run good RG-6 coax from the matching transformer DIRECT to the Tv. No splitters , no antenna amps , No antenna amp power supplies , no cable tv hardware , No satellite tv hardware . The hook up will be , antenna , matching transformer , coax , tv. Also the tv must scan for , Broadcast Digital Tv Channels , NOT broadcast tv analog channels , NOT cable tv analog channels , NOT cable tv digital channels.
